Cable limiter availability?
AlbertL57
Falls Church, VA
Solar maintainer
No supplier seems to stock them, and they're quoting lead times of 6 months or more. Does anyone know what happened to that supply chain?
Are those allowed to reduce AFC to cheaper equipment ?
No.
Usually, they are intended to open a faulted cable in a parallel set of conductors. They are not designed to be used as a backup OCPD.
I don't think I have ever seen a trip curve for a cable limiter. Without knowing its opening time you would not be able to calculate the resultant incident energy.
I'm mystified. How are these different from a fuse or circuit breaker? The spec sheet appears to only deal with wire size, and doesn't mention current... How does it -know- it's time to open the circuit?
Yes, it does seem mysterious! You're correct - they are rated only by wire size and material (e.g. 250MCM Cu). Internally, they must have some kind of fuse element, apparently rated only on the basis of preventing the wire or insulation from melting.
It sounds like a large fusible link.
Which open after the conductor has already faulted, hopefully preventing/reducing damage to the other conductors in the set. It may be better to limp along on a reduced number of parallel conductors than it is to lose the entire facility while waiting for new conductors.
The paperwork says they don’t offer over current protection, just short circuit. Personally never even heard of the things, let alone installed them.
I believe a lot of their use is on the utility side, specifically on secondary networks (multiple transformers paralleled on the LV side, usually underground) where available fault currents are very high. By quickly isolating individual faulted cables, the limiters help maintain service continuity.
Bussman makes them. Not sure why the long lead time. It's essentially a current-limiting fuse. Here's a TCC for 500 kcmil Buss limiter (according to EasyPower).
How does thus compare to a typical OCPD? Your example is for a limiter to protect 500kcmil which is typically applied at roughly 380A. The TCC shows this limiter would carry roughly 2500A for10 sec before opening. This doesn't seem like it would be easy to coordinate with.
