cable lug torques
Davis9 said:
Thanks for the pic. I'm guessing the local supply house doesn't have that one.
Tom
If you want to make the counterman's day...ask him ...LOL
I think a tool like that is not in the supply house....but it would sure be funny to see someone ask for it!
Celtic:
Counter men want something they understand or a part number if they do not understand what you need they say "we do not stock that".
My (3/8") torque wrench reads in ft/lbs... so I convert to inch/lbs.
I torqued some main lugs yesterday.....GE meter Main and Square D Breaker panel.
GE spec. called for max 200 in/lb. so I torqued them at 16 ft/lb.
Square D (Homeline) called for max 250 in/lb. so they got 20 ft/lb.
How many of you carry a torque wrench (rated in in/lb.) that will go to 250?
I suppose the accuracy is better on a in/lb. wrench although torque is torque and if the wrench is calibrated, either should be OK.
How many torque the connections on branch circuit breakers, ground connections and receptacle and switch connections?
Just curious
steve
Just curious
steve
You need a little more torque there don't you? Edited I now see the "max" part.
I've also noticed that most manufacturers include a Newton Meter value as well.
200/12=16.6
250/12=20.8
I haven't been able to find a receptacle torque value. I wanted to make sure the cordless driver provided enough torque.
Tom
It shouldn't be much of a problem to find one. Klein, SK and Wiha all make torque screwdrivers, along with many other companies. Here's a Klein
and here it is from Sears under the Craftsman name:
http://s7.sears.com/is/image/Sears/00934887000?rgn=0,0,640,640&scl=1.28&fmt=jpeg
I got my Klein as a set from Sears:
These are for small torqe values, which is why I also have four torque wrenches in various sizes and ranges.
mgd said:
how often are your torque screwdrivers calibrated, out of curiosity?
I haven't had mine all that long, but it will go on a yearly cycle with my torque wrenches.
(now I have to confess that one of my customers is a calibration facility)
