Can a cable located on the load side of an ATS switch be protected by a breaker on the line side of the ATS? For instance if there was a #6awg cable rated at 65A on the load side of the ATS could this be protected by a 60A breaker at a panel on the line side of the ATS?
What if for this same case the #6 cable had a 100A breaker at the upstream panel on the line side of the ATS however there was a 60A main breaker at a panel on the load side of the ATS that the #6 cable fed into? Would this be a version of the tap rule?
