Eduardo Maun
- Qatar
I find sometimes that they used different cable size but the breaker rating is just the same, One factor I think because of the load connected to it.
Ex. 100A they used 4 core x 50 mm square; 100A they used 4 core x 35 mm square, Is temperature a factor?Is there any other factor that affects the cable size?
Or both cable size can handle a 100A? Is it for safety reason why they used 50 mm sq.?
Thank you!!!
Thank you!!!
