rswolff001
customer has several portable pieces of equipment using a wall mounted 3p 480vac 60a hubbel receptacle and 3p 480vac 60a hubbel plugs and SEOOW cable. A new piece of equipment requires only 30a and has a 30a plug and cable. Can I simply replace the plug or do I need to also replace the cable from the plug to the machine?
Next question.
On the new piece of equipment the cable feeds into a 30a disconnect (non-fused). If I change the cable, I'll also change the disconnect. Do I need to also add an additional CB or fuses? The disconnect already feeds into multiple CB's.
Thanks, Bob:blink:
Next question.
Thanks, Bob:blink:
