Strahan
- Watsontown, PA
Guy's I need some help. I'm in the process of wiring some tanks that have RTD's installed on them. I want to run multi-conductor sheilded cable to each of them but I'm reaching a road block with the NEC. I plan on running them above the drop ceiling and then dropping them down to each RTD. I want to fasten them to the conduit drops I currently have in place for the pump motors. Type of cable that I have is Belden 9534 CMG shielded. They will not be exposed to physical damage. Is this install ok by the NEC? It's not a power circuit just resistive signal from RTD's. Thank You
