Calc Help
Ok thanks for you help i wish i could stay in this thread this is the most help ive got in a long time im leaving to take the supervisors test now wish me luck i need it!!!!
Im not sure if i passed that test it was very hard! The last half was a service with 2 feeders one for a copy center that had multiple loads the second was a restaurant that was optional all electric . One of the listed loads was 6 600watt heat lamps do you think that should be continous x125% all the other loads stated continuos or noncontinuous . Its 50 /50 if i passed i know i didnt calculate the nuetral right on the optional , i did calculate it as a standard nuet. I added nuetral loads that were 3 wire such as range and oven then reduced x.70 well see im going to post some more and keep practicing . Thanks again to everyone who helped
Your heat lamps should probably be considered continuous. Probably for a food warmer that's on all day.
