Electric-Light
Under conventional definition, the neutral carries the difference in current. If you have a 1kW light bulb on each side, the neutral current is essentially zero.
What about given:
A = 1kW space heater, 120v 8.33Arms. PF = 1.0. waveform is sinusoidal.
B = 1kVA 600W in CFLs and computers. 120v 8.33Arms, PF = 0.6. phase shift = 0 deg. Waveform is what you normally see with bulk-storage capacitor/rectifier input load type.
I don't know how you'd calculate it, but I doubt its zero.
Red shows A side current waveform. Blue shows B side current waveform.
What about given:
