I am reviewing plans for a residential car charging station. 240v and the charger has the ability to charge at multiple output ratings from 16 amps up to 60 amps, the amperage can either be set within the charger or it can be changed with an app on your phone. The manufacturer makes mention in their spec sheet that the OCPD need to be a double pole breaker rated at 125% of the load, simple math tells me that the OCPD would need to be a minimum of 65 amp rated breaker since they do not make a 62.5 amp breaker. Am I missing something here?
Thanks.
Thanks.
