- Wisconsin
- PE (Retired) - Power Systems
Where did the OP state the 'lamps' were tungsten?230103-1003 EST
ggunn:
Where in the original post was there any mention of "power" being held constant? What is held constant is the total line to line voltage.
And by implication, since tungsten filament bulbs are the load, the relative bulb resistances are very different between each other when the center wire is open vs closed.
Where in the OP did it say the problem should be solved over a time range rather than at a singe point in time after the system has stabilized?
