California contractors licensing, please explain
I understand and agree that a Genteral Contractor can file an electrical permit when more that two trades are involved, but please show me the text of the law that permits him or anyone else to perform electrical work without being licensed electricain with the State of California.
108.2. (b) (1) Certification is required only for those persons who perform work as electricians for contractors licensed as class C-10 electrical contractors under the Contractors’ State License Board Rules and Regulations.
So you could just be a general-B and say you do electrical, and throw in D-63 Construction Cleanup.
There is a good chance your doing some cleanup on every job so there are two trades .
There is 5-6 other 'trades' they classify, all that a C10 also does as one trade that general-b could use to say they are doing more than one trade,
C-47 Solar, C-7 low voltage and or class C-45 sign circuits and HVAC whatever that one is.
Stranger still seems like if your a solar contractor C-47 now are you required to switch to a C10 but they acknowledge the general B exemption:
Thats very odd.
Unfortunately, at this time the CSLB only enforces violations of the Contractors State License Law is when a consumer files a complaint against a contractor, or it is a "Sting" operation. This is because of limited resources.
Yes, many remodel-construction defects begin with the missing smokes, the tip of the wiring-hazard iceburg.
California construction class R3 buildings can't all be policed by CSLB SWIFT sting projects, but they are regularly molested by unqualified persons, and DIY undeclared-defects that disqualify all insurances.
So a general B business can hire whomever they want and pull a electrical permit ?
Perhaps not beyond Owner-Builder's signing off on indemnity clauses.
More commercially managed properties force building permits, but weather the clueless AHJ's demand C10 electricians for the electrical is unknown to me.
Sad ... but true. 90% of resdential work is done without a permit !
And, yes the IBEW lobbied heavely for licensing for electricians in California, and have moved on to the other states.
Here in Oregon you can't get a utility to energize a electrical service without a permit and inspection, is that not the case in CA?
EDIT: or is that the other 10% of the work?
Perhaps 90% of existing dwellings are molested by un-insurable hacks.
Perhaps new construction permits & inspection can be enforced, where hacks can't tap into existing meters, pedestals, or well-pumping units.
I was wrong on the California General Contractors being required to also have licensed electricians to perform electrical work. After doing additional research, this new law only applies to California C10 Contractors.
Thank you all for your patience and understanding ! ...
Thats very odd.
Solar is C-46, for the record.
The CSLB decision referred to in that article only applied to systems with energy storage. However that decision was also withdrawn because it was made unlawfully without the required public input. They are still trying to push forward with it, notwithstanding that it's just anticompetitive and a solution in search of a problem.
I was always under the impression that a B lic holder that also had a C10 lic, would also need to use certified electricians, or am I mistaken?
When the IBEW lobbied for this bill, they left out General B contractors. General B contractors are the top classifications in California, so maybe they wanted to reduce opposition. But, it seems unfair to require only C10 contractors to hire licensed electricians. So, at this time if a contractor has both a General B and C10, just pull the permit under the General B. Seems like a "Loop Hole" to me.
Apparently this is true. For work that requires certified electricians, that is. For a smaller contractor who was doing electrical incidentally as part of a larger contract they could get around it by making the connections themselves (the qualifying individual that is).
It seems to me that the law only applies to the actual making of 'connections', but not to running cable and raceways and such. YMMV
Why even bother being both a general B and a C-10 if a general B can pull an electrical permit?
Seems like as soon as your company has a C-10 then you need certified electricians, regardless of the general-B?
A B is not supposed to contract for work that only involves electrical. If you also have a C-10 then you can. Actual enforcement of this seems to be up to the permitting jurisdiction and is quite spotty.
Again, you don't need to use certified electricians unless the work is electrical. But yeah, it's dumb that if I'm a B I can have my carpenters do the electrical after they finish the framing and before they do the drywall, but if I get a C-10 because doing service upgrades is also up my alley, then maybe I can't have my carpenters do that previous electrical work anymore.
The stickier situation is having a C-10 and a C-46, or some other similar combination.
A massive loophole is "D-63 Construction Cleanup" every service change involves demo and construction cleanup, so a general B could be doing two trades and do service upgrades.
The two trades have to be 'unrelated' so unless you have something to clean up besides wire that claim might not serve you very well in a serious CSLB investigation. You're probably better off painting your conduit and claiming painting work. But who knows, I haven't heard of any jurisdictions making trouble for B contractors, and that's probably because a B is allowed to pull a permit for anything if they subcontract the work to an appropriately licensed sub. You only have difficulties if you're some kind of C, say a C-46 doing a service upgrade or subpanel that's 'necessary for solar.'
OK I get it now.
So in that case if General-B Co. gets a plumbing and electrical permit for a kitchen remodel, and subcontracts to a C10, the C10 is never mentioned on the permit? Just electrical permit by General-B Co?
The “B” General Building Contractor license is the most common contractor license classification in California, with almost 104,000 active licenses
  • CSLB - Fast Facts, General B.pdf
So I am confused that PDF states:
Solar Energy Systems – A “B” General Building contractor may
contract and self-perform installation of a solar energy system on a
structure because installation of the solar energy system constitutes two
or more unrelated trades pursuant to Title 16, California Code of
Regulations Section 832.62(b)
So why would anyone bother becoming a solar contractor C-46 when being a general B covers it?
Just so you can subcontract solar?
Seems like it would be easier to just be a General-B and do a solar install, that includes a service change and energy storage.
That's correct. The permit would be for something like residential alteration.
Because if your experience is actually in solar then you would find it a lot easier to answer the questions on the C-46 trade exam with minimal study, instead of having to cram info about framing and foundation requirements you had no idea existed. Also you need 4 years experience to qualify, and if that wasn't working for B contractors then you might not qualify to take the B exam. Not entirely sure about that but definitely could be the case.
