- Placerville, CA, USA
- Retired PV System Designer
The Panasonic unit I have experience with turns the indoor fan on at low speed for a short period of time at intervals when there is no heating or cooling demand. So the extra breeze is minimized. But you can also set the inside fan to run continuously for better temperature regulation.One specific design issue of these specific units is that the indoor temperature sensor is built into the indoor unit.
This means that the system has to circulate air when the call for heat has been satisfied (at least that is my understanding for why it was designed to do so), and so the system will produce a cool breeze between heating periods when heating requirements are low.
Regarding the low temperature function, I should be clearer: I do not have personal experience with the system on the coldest days. I did not mean to imply that I wouldn't like the system on the coldest days. I did _try_ one of my units on a really cold day last year. It seemed to sound like it was struggling, but it did make heat.
Jon
The weakest point in the unit operation, in my opinion, is the implementation of Auto Heat/Cool. The problem is that regardless of how you set the heating and cooling temperatures, there seems to be an almost 8 degree dead band between Heating and Cooling.
For a system with two indoor units, the problem of manual Heat versus Cool selection is tedious. To be sure that the switch is immediately effective, I have to turn off both indoor units, change Mode on both of them and then turn them back on again.
