California Journeyman licensing requirements?
This part is incorrect. The CSLB licenses contractors. The Department of Industrial Relations (DIR) certifies electricians. In California, contractor licensing and electrician certification are separate, essentially unrelated processes handled by different state departments.
Again, DIR not CSLB. dir.ca.gov
What he probably needs to do, if he wants to become a journeyman electrician, is either enroll in a qualified training program, or find a new job with someone who has certified journeyman and will walk hin through registration as an electrician trainee. Or better yet, both.
WOW!
Since when have you been correct regarding directives issued by
CSLB.
NOTICE
To all electricians working for C10 Contractors
Here is an excerpt of the notice sent to my office dated Oct 2, 2006.
As ( written) verbatim:
Electricians “ include all persons who perform work as electricians for contractors as Class C`10 contractors under the CONTRACTORS’ STATE LICENSE BOARD (CSLB) rules and regulation or electricians who engage in the connection of electrical devices for electrical contractors licensed pursuant to Section 705B of the Business and Profession Code, specifically contractors classified as electrical contractors in the Contractors’ State License Board Rules and Regulation.”
For more information on certification requirements or registration and testing, please visit our website at www.dir.gov/DAS ElectricalTrade. htm
or
you can call us at (415) 703 4919
There is a BALONEY vendor at TEMPLE and BEVERLY in downtown LA-- not in MH.
WOW!
CSLB.
NOTICE
or
Seems like I've been correct since at least Oct 2 2006. That notice is from DIR, just like I said.
If I get a et card I may put Myself out of work if it is found that there are no licensed journeymen here, so I’m not sure what to do.
Find a C10 employer who follows the rules.
It seems you implied that I may still get work hour credit while working here under c10?
Just guessing here, but I think the CSLB is more likely to credit those hours than DIR. But that only helps you if you want to get your own C10 and run your own business.
NOTICE
or
This notice is over 16 years old, with several errors, and was not written accurately at the time.
1) 705B does not exist.
CA business and professions code has always started with section 7000, not 700.
2) www.dir.gov/ does not exist.
3) 415) 703-4919 does not reach the contractor state license board (CSLB).
This number may still be helpful, and is registered with department of industrial relations division of apprenticeship standards.
You can qualify without ever having an ET card. I went through about half the WECA ET program while employed by C-10s to keep my ET card active. Got my card without finishing the program.
You need 8000 hours worked to qualify, however they only go off the social security wage transcript you submit, but it only shows wages, not hours worked. As long as you have 4+ years worked with 2+ of those being under a c10, you'll get through. The more employers the easier it is.
Nowhere do they ask if the contractor was a c-10 or the hours worked at each employer. You fill in the hours worked for each task category, they don't care where those were worked, nor do they have a way of verifying.
The staff at the CSLB is very limited. But when a complaint is filed by a homeowner, the microscope is implemented.
How long ago was that? I read somewhere that they've been more thorough about looking up the employers in the last few years.
If I get a et card I may put Myself out of work if it is found that there are no licensed journeymen here, so I’m not sure what to do. It seems you implied that I may still get work hour credit while working here under c10?
Hey I just read your post and nothing else so if it’s been mentioned my bad.
If you need the et cards. Get it screw your boss he just using you, with all the training and knowledge you claim to have you should be the best apprentice anyone could want you will find a job.
Thanks ac/dc
Move to oregon seems like every California is :mad:. Ill Hire you! Can’t find good help around here. Lucky if they can walk straight.
Lol yea my job keeps firing employees before their hired due to failing drug test for meth and or Haroin
