Joethemechanic
- Hazleton Pa
- Electro-Mechanical Technician. Industrial machinery
Having unswitched power at both ends is certainly an advantage but you can do that with four wires the regular way tooThe diagram is from the Wikipedia article:
Multiway switching - Wikipedia
en.wikipedia.org
There it is called a 'California 3-way'.
This is a legal system that has the benefit of having switched and unswitched hot at both switch locations with only 4 wires.
Later the article describes the 'Carter System', which is illegal because it switches the neutral.
I learned 'California 3-way' as a synonym for the 'Carter 3-way', not as the Wikipedia article describes it.
Jon
????You've got to think the old solder method romex type of wiring
Nope solder stayed around for cloth romex it was late 50s that rubber taped crimps became standard here????
Solder went out with the adaptation of Romex, aka NM cable, where splices were made in boxes.
Here, let me fix it for you (FIFY)
You've got to think Knob and Tube wiring.
I've only seen the "Chicago 3 way", aka Carter, in the field, the one that switches the neutral. Lots of K&T still in Richmond.
I wouldn't chose solder for interior work other than strip lights but I wouldn't be against it for new underground splices but I have a crimper that I trust just as much and it is way faster.I didn’t stop soldering joints in resi work until at least 2008, maybe 2009. Pretty common in my area; there’s still a few of guys here soldering that I’m aware of as the supply houses are still keeping solder on the shelf for them.
You can still get them from idealI can remember my grandfather using a crimp that sorta looked like a wire nut way back in the day. They were 3 pieces. There was a copper band that you crimped, then a black rubber hat that went over it, Then there was a red plastic ring that you pushed down over the top. The red ring was knurled on the outside
Here I started noticing Ideal Wire Nuts being used on Romex (lots of home building in that time in my neighborhood, like Larry's childhood home...), as a child, and that was late 50s. I've got lots of old Wire Nuts I pulled out of houses built in the 20s and 30s that were being torn down when I was a teen. Part of my personal old electric equipment museum, or junk...Nope solder stayed around for cloth romex it was late 50s that rubber taped crimps became standard here
Here are the crimps, and I posted the tool above,Here I started noticing Ideal Wire Nuts being used on Romex (lots of home building in that time in my neighborhood, like Larry's childhood home...), as a child, and that was late 50s. I've got lots of old Wire Nuts I pulled out of houses built in the 20s and 30s that were being torn down when I was a teen. Part of my personal old electric equipment museum, or junk...
What is a rubber taped crimp?
Rubber taped split bolt, now that was for motors, never residential.
