Coppersmith
- Tampa, FL, USA
- Electrical Contractor
Not necessarily. Some places have legislation in place that forbids the inclusion of a PV system in a property assessment. I do not know about California, though.If the net result is a negative electric bill, then this mandate might actually be worth it to the people buying these new houses. But the numbers are really not clear.
1) The solar install may add value to the property, and so raises the property taxes.
True enough, but installed subsidies are up front so changes after the fact don't affect ROI. Most places have locked in net metering contracts which protect customers from later tariff changes.2) The calculations of installed cost and benefit depend heavily on subsidies, both actual cash subsidy and 'net metering'; these subsidies could change
Again, not necessarily. If PV systems relieve or ameliorate the utility having to go to the spot market for power during peak periods, that reduces costs for everyone. Also, here in Austin for example, The Value Of Solar method of calculating the financial returns on a PV system (solar kWh's pay everyone the same irrespective of what usage tier the customer is on) does a lot to level the playing field. For another thing, community solar projects are popping up all over the place where anyone can buy into a system and have their portion of its production figured into their electric bill through virtual metering.3) Especially with respect to the net metering subsidy, energy costs will be increased for other consumers; IMHO lowering costs for rich folk who can afford new houses and raising them for poor folk who don't get the benefits of the solar install.
True dat.On the plus side, like computers and other electronics, solar power is essentially carefully organized sand. A huge portion of the expense is capital investment in the production facilities. The more users the less expensive it becomes.
What's unaffordable about a negative electric bill?
Might I remind you or educate you that California is the state that put car pool lanes in and free bridge tolls for people in car pools. Then once they got enough participation that claimed they were losing too much money and started charging tolls for car pools. Encourages high MPG cars and then raises gas taxes because people are using less gas. Good luck with that negative energy cost. And FYI I was a Californian for 25 years so I am not just a Floridian speaking out my butt.
Remember when "Pssst ... want to buy a bridge?" did not mean that you could actually buy a bridge?... Remember when tolls were collected to pay for roadways and stopped when the roads were paid for? ...
Putting a gun to someones head and forcing them to install systems that they have to pay for and may not want is un-American. I'm not surprised that they came up with this scam in California.
Kinda agree, but on the other hand you can say the same thing about pretty much any building and energy code.
I'm all for safety as part of the building code but this goes beyond that.
What about energy codes requiring certain glazing or insulation levels?
But in the same manner the generation and transmission they have to have to be able to supply all of the load when solar is not available increases the cost for everyone as they are selling less energy and that means they have to charge more per unit to cover those costs. If they can't cover the costs of the infrastructure needed to supply all of the loads when the "green" supplies are not available, they will no longer maintain that equipment, and we will not be able to expect that the lights will come on every time we flip the switch....
Again, not necessarily. If PV systems relieve or ameliorate the utility having to go to the spot market for power during peak periods, that reduces costs for everyone. ....
There is no negative aesthetics that go with things like that. IMO nothing looks worse on an expensive home than ugly solar panels. If one wants to live with the ugliness to get free energy that should be by choice not government mandate.
I'm curious, though. Will the new homes that have all these solar panels actually be able to use the power they produce, or will they be like Florida and not be allowed to? IE, when the grid goes down, you still have no power.
The panels are designed to stop producing when the grid goes down for safety purposes. Otherwise they would backfeed the grid and shock a line crew. I believe that if you have a transfer switch and a small generator, they will still work.
