sparkync
- North Carolina
Got a call to check why a camper kept tripping a 50 amp breaker that was feeding a 50 amp camper 4 wire plug.
Long story short, found the 50 amp breaker was GFCI. The camper has its own gfci protected outlets inside, so I had to install a regular breaker to keep the family with power. While checking it I seen that the plug from the breaker was installed with only 3 wires instead of 4, therefore the whole camper is actually using the equipment ground for the neutral, from the outlet box back to the breaker. The only feasible way to correct this without pulling the 3 wire out of the ground, and pulling new 4 wire is to send only 120 volts over to the plug, and use the other leg (which is white anyway) as the insulated neutral, and just change the terminations in the boxes to match the camper cord. All the camper needs is 120 volts anyway. This prevents the potential of current traveling on the frame of appliances, etc., that are hooked to the equipment ground and neutral bar. Is this
correct? Even though the conductors are all separated until they get out to the 50 amp camper recetacle? They are using a 50 to 30 amp adapter, that reduces the voltage to 120 volts instead of 240 volts by using only 1 leg of the power supply.
I know according to code it should have been 4 wire out to the plug instead of 3 wire but is this still a hazard since the connection is out at the outlet and not inside the camper? Sorry for the long discourse but trying to determine the necessity, before traveling around 60 round trip miles to correct.
Thanks a lot for your replies.
