I just read it and can’t understand part of it.
230.85 (B) disconnects. Each disconnect shall be one of the following:
(1) Service disconnect
(2) a meter disconnect integral to the meter mounting equipment not marked as suitable for only use service equipment installed in accordance 230.82
(3) other listed disconnect, switch, or circuit breaker that is marked suitable for use as service equipment, but not marked as suitable only for use as service equipment, installed on the supply side of each service disconnect.
Info note 2: equipment marked “ suitable only for use as service disconnect” includes the factory marking “ service disconnect”
Seems a little contradictory. It shall be a service disconnect and then also can’t be equipment with the marking service disconnect.
