flatlander
- Diamond bar, CA , Tempe AZ
1) It says Class A, on the device yolk - Blow up bottom right diagram--
2) Does "Not listed" mean can't be AHJ approved in the field?
3) If 2-pole GFCI breaker won't fit in fuse box, HC-GFCI in deep 2G box / 1G P-Ring with this relay mounted to back of box
4) If no 15A/20A convenience circuit is available to control the 20A GFCI, add a fuse block
Let's see. Buy a specialty device,add relay,get a box,punch a Gfci slot,Mount all this stuff.wastr of time.
That's a hell of a lot work to Gfci a receptacle. Throw a breaker in the panel and be done. Way over thought.
