Can anyone figure why the fuse?
It's not drawn in any way I would ever draw it but I think what's supposed to happen is when the normal Power fails the relay deenergizes and normally closed contacts turn on the emergency lights. I think the pull fuses are for testing.
Thank You. So I am trying to create a similar diagram for an ALCR and if I want to achieve the same purpose with pull fuses as the first diagram, should I insert them here?
terrible drawing
makes little sense
why 3 wires to the relay? trigger?
when Sk is closed you have H on both sides of the relay?
when open you have zip
as far as I can tell relay NEVER activates?
The ALCR diagram is good. I just am not sure where to insert the pull fuse.
this is what I think is desired.
This is exactly the same diagram as the first one I posted. This is fine when EMRG. and Normal lights are on different switches.
When EMRG. and Normal lights need to be on the same switch then you need the ALCR diagram I drew, one of the inputs is the switch sense.
I guess the pull fuse goes only on the Normal 120V before the switch.
