Installer
- DesMoines, Washington
Eaton sells a 30 AMP, 2-Pole, General Duty Safety Switch, Fusible with Neutral rated for 240 VAC,
It uses type FLNR fuses, which come in 20 A. So by using a 20 A fuse, do I effectively make the 30 A switch into a 20 A switch?
Likewise, can I take a 60 A switch and use it as a 40 A switch by using a 40 A fuse?
As everyone knows, 30 A and 60 A are industry standards and 20 A and 40 A switches are not..
Thank you in advance
