e57
- San Francisco, CA
I see this may be one of those things that you have a cemented an opinion on that will not change by anything I would or could ever say - and since I lack the 'qualification' to change your mind - we might as well add it to the ever growing list of things we have agreed to disagree on - is that correct?The second building is not being supplied by a second service it is being supplied by a feeder or branch circuit. (and in the case of a switch leg is not even being supplied)
Services end at the disconnect.
Would you say your refrigerator is supplied by a service or a branch circuit?
If it isn't - A simple yes or no to the two questions posed earlier would be nice...
- Two services on the same structure without fitting a need by qualification or special permission would be a violation?
- Two branch circuits or feeders on the same structure without fitting a need by qualification or special permission would be a violation?
Anyway - if you followed the OP from thread to thread, sometimes its a 3-way, sometimes it's a sub-panel from one property to another property, across possibly another property. Both buildings have an existing service. It's unorthodox to say the least. Regardless of who they may all be owned by at the moment - should we be advocating such an installation?
For the record: My refrigerator is powered by a branch circuit with OCP, from a panel and feeder, from the OPC for the feeder in a main panel with OCP as the single source of electrical energy to my premises at my single service entrance and disconnecting means.... With no other source from my neighbor across the street...
