Can I use this luminaire in ceiling tiles?
I'd guess some tiles will sag easier than others, most you typically find in dwellings will likely sag some within a year. May not be too noticeable but as Fred B mentioned won't even take the weight of a smoke detector without sagging. Lights in OP probably around same weight, probably more if the driver ends up supported by the tile.
We did mount the drivers to the floor joists above.
