Hi, I'm looking for some help. My electrician seems a little confused and maybe it's time to hire someone else but I wanted some advise before I go spend a ton.
I have a 3 phase 240v panel that has a.c., and 6 frozen yogurt machines hooked up. Just before plugging the machines I read the label on the machine said 208v -230v. I was assured by the previous licensed electrian that they would work. The tech that works on these machines said no I need to step down the voltage.
So now we are trying to find a buck transformer for each of my 6 machines rather than lower voltage to the whole panel because the a.c. is on the same panel.
1.I need help identify if I have delta or Wye.
2.I need help finding the right part to order.
Machines are 208v-230v, 5kv, 16 max amps each.
Current voltage at my outlets is between 240-245
