gar
- Ann Arbor, Michigan
- EE
210520-2140 EDT
synchro:
If you have a center tapped winding with the center tap connected to one end of a voltage source source, and an outer end connected to the other terminal of the said voltage source, and place a load across said two terminals, then that load can be as large as the primary power source can provide.
Loading from the center tap to the opposite end uses the the transformer as an isolation transformer, but having two ends of the two coils electrically connected. Changing the phasing of one of the windings does not change this.
However, if you use the transformer as an autotransformer, you have the functional results of it being an autotransformer.
synchro:
