Caught this and has me thinking. It's suggested there could be a problem with the utility.
"Tonight my wife mentioned that she can feel a slight shock if she puts her hand in the kitchen sink drain. There is a garbage disposal so I assumed that may be involved.
I tried sticking my hand down there and couldn't feel anything, but I got out the multimeter and there is 1.8 volts between the metal sink body and ground. If I hold the probe in the water stream and put the other probe in the ground on a nearby receptical I still get 1.8 volts. There is no voltage between the body of the disposal and ground. It seems that the disposal body is acting as part of a ground path in the circuit that causes my wife to get shocked. I even turned of power to the disposal and get the same results.
No other sinks in the house have this issue, including one that is a few feet away.
The cold water pipe is bonded where it turns to copper, but it enters the house as pex.
I can see the entire length of the pipes between the sink and where the water enters the house. There are no wires touching anything, except the ground. I checked for voltage on the ground at that point and found none.
Basically, I don't think it is an issue with voltage on the ground.
Has anyone got any ideas? My next step is to start isolating the source of the voltage by turning off circuits one by one and see if it goes away. Next after that is call an electrician.
Ok. To follow-up.... I just went through every circuit in the house one by one and I still get voltage. Then I tripped the main breaker and I still get the exact same reading. 1.8 volts between the body of the sink (or the water stream) and ground.
This isn't showing up on any other sink, so I don't think I have a bad multimeter.
This sink is the only one with a single handle faucet, so hot and cold are mixed, but there are no other significant differences between it and the others.
Granted , 1.8 volts is a pretty small amount of voltage. I can't feel it myself, but my wife says she does."
Anyone run into something like this?
