Eddy Current
I know salt can lower the resistance of water but is there a way to check waters resistance. Just wondering, and do they even make such a meter?
I'm not getting why putting the apparatus he demonstrated in a bathtub full of water would cause the person in the bathtub to be electrocuted.
- :dunce:
Why would the solution of salt in the water make a person IN the water be more likely to be electrocuted?
- :dunce::dunce:
- :dunce:
- :dunce::dunce:
Where is the fault if the water is not conductive? There is no fault to ground. I did this experiment- the bulb will stay lit under the water with a perfectly good GFCI attached to it. Inspectors would not believe it so I did a demo for them-- please don't do this unless you know what you are doing.
In the beaker water experiment, I see that there IS no fault current...and it would not trip a GFCI.... however the video guy said a bather in a bathtub would be more likely to be electrocuted with the addition of salt to the bath water... seems to me just the opposite.
Electric Shock Drowning doesn't occur in salt water because salt water is a better conductor of electricity than the human body
My God that's horrible.Electric Shock Drowning doesn't occur in salt water because salt water is a better conductor of electricity than the human body
http://www.huffingtonpost.com/terry-..._b_693454.html
The whole concept is hard for me to wrap my head around. From where is this electricity originating, and why is it flowing through the water? Are these boats plugged into some land based source when this happens?
