Coffee Cup
- Boston MA
Hi All,
I have a situation where there is a 12" x 12" x 4" flush mounted pull box. We want to bring in two 3/4" Liquidtight non metallic connectors to feed the solar generated AC into the main panel, the cover of this box has access to the 2" conduits to both the panel and for an outside disconnect. It seems to make the most sense coming in the front without disturbing the wall (it was a semi prefab house). I have looked through all the general articles and don't see anything that says I can't. 314.22 and the exception addresses surface extensions for boxes, but it doesn't necessary address this. I know you can buy 4" and octagonal covers with KO's, so maybe it's ok.
Yes it will be a flexible connection to facilitate removing the cover. Yes there is plenty of space in the box for the connections. No it will not compromise grounding.
The forums thoughts on this would be appreciated.
Thanks
John
Just because code doesn't say you can't do it, doesn't mean you can
Thanks
John
