Honestly I'm not sure, that is what the architect is calling on his drawings. From my understanding it is a wall assembly designed and constructed to limit the movement of smoke. Doesn't require a fire rating. Openings are protected.
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.
Even for fire rated walls the panel can be recessed. It would need to be installed in a fire rated niche built into the wall. I would assume that something similar could be done for a smoke rated wall.
