can you run on the ground tempoary wiring in pvc for an
jonesjax
I need to run temp power for a house burn out house. The project may take as long as a year.can I run a pvc pipe on the ground next to the work site. It is for the pool and sprinkler system. do I have to find a way to fasten the pvc to the grass. Would this be an OSHA violation? The customer has underground sprinkler system does not want it cut???
Thanks
Jacksonville, Fl
Re: can you run on the ground tempoary wiring in pvc for an
Talk to your local AHJ to see what they will allow.
Bill
I would not accept any temp. wiring for a pool, there would be to much of chance of that wiring getting damaged during construction. check with your AHJ.
