i like to use a simple compass, If the circuit holds then the wire give off a magnetic field, slide the compass in the general area and n will point to the box.good luck
That's a idea i've never heard of.
I'm gonna check that out....i like to use a simple compass, If the circuit holds then the wire give off a magnetic field, slide the compass in the general area and n will point to the box.good luck
It cant be a back stab issue. He said it's 12-2.
Be sure to check all the switches, just in case it is a switched receptacle.
One difference is that the 4000 series has one transmitter that works for either energized or non-energized wiring, The 2000 series has a separate transmitter for each.I looked into the Amprobe line. So many models, but I would like to know if anyone can comment on the differences of the 4000 line and the 2000 line.
Thanks
I find this tool handy for finding boxes that sheet rockers cover up on purpose.
That's one that a lot of people forget about. You kind of expect to see three conductor on a switched receptacle with only half switched but some people do switch the whole receptacle.
I live in a mid-70s home and each bedroom has only 2 receptacles ... with one of them being fully switched. Talk about a PITA!!
I wired homes in the mid seventies, in two states, opposite sides of the country, and in both of them we had to follow the nec rules. The six foot rule had been around for years and years even back then. Two receptacles in a bedroom is a mighty small room.
Too bad you don't know a qualified electrician.![]()
It started out as simply 'a sufficient number evenly spaced' when it was introduced in 1937. In 1940, it was changed to 'no more than 20 feet apart'. In 1956, it was modified to the 12-foot rule known today.
That's why I'm a fan of split-wiring receptacles.It's just that the switched outlet always seems to be the accessible one!!
