Alwon 1951
- Chapel Hill NC
I can't even add an avatar but my interface is the same..... The media tab only show Videos not photos. No camera icon to even add photos
856 bytes maybe? GIF files can use run-length compression to reduce file size when there are large areas of a uniform color. An uncompressed black and white bitmap of an 83x100 image could be as small as 8,300 bits plus some header bytes. That would be about 1000 bytes. An image with only a few colors can use a custom color list to represent all the colors actually used in only a few bits per pixel. Combine that with run length endcoding and 856 bytes is not impossible.Interesting Dennis. 856 kiloBytes is huge. I got vBulletin ERROR declarations on much smaller GIF file sizes.
Let me ask, when you go to your "My Profile" and you look at the tabs extending to the right from your avatar, do you see four tabs (like file folder tabs) "ACTVITIES" "SUBSCRIBED" "ABOUT" and "MEDIA"?
And when you click on the "MEDIA" tab, does, what opens, include "ADD PHOTO"?
Mine doesn't. And, according to the vBulletin HELP documentation, it is supposed to.
Wasn't this was all 'field tested ' before it's debut?
~RJ~
The jpeg upload is fixed 2mb limit
The answer is, yes, of course it was tested. The second question is "Was the testing rigorous enough, judging by the number of residual problems?"
And the answer to that is, probably not.
