Johnmcca
 - Mid-Hudson Valley, NY
Its stuff like this that makes me glad I don't do pools.:grin:
			So given the code section How does the transition to the carflex or liguid tight with a insulated Ground still pose a issue.
Install a mini sub panel and use an aproved method from there to the spa tub. Whats the issue.
From the main to the spa panel is a feeder not a branch circuit especially if you use the type with a GFCI recept attached.
Good point. So if that is the case I would think the 2 space panel I mounted out side next to the hot tub which contains the 2 pole GFI breaker could actually be considered as a hot tub sub panel.
We might also be getting off the actual subject. The original problem is that Romex can,t be used in a residence to feed the hot tub because the Hot Tub unit has a factory light. At least that is the argument from my inspector.
I still say she's incorrect. You're not feeding the light, the manufacturer did that. You're supplying a (presumed to be listed) packaged assembly, and, in my opinion, your responsibility ends at the wiring compartment.We might also be getting off the actual subject. The original problem is that Romex can,t be used in a residence to feed the hot tub because the Hot Tub unit has a factory light. At least that is the argument from my inspector.
My inspector is very good and she is very through. I respect her and enjoy talking code issues with her. She is adamant she is right and also claims she has brought this subject up at conferences she attended and also spoke to the NFPA guys and they all side with her.
How can I help her see it my way?
