nosparks
- Massachusetts
My electronics background is very weak.
Scenario: I have an oil heater on a Cleaver Brooks 500hp boiler. A thermostat will pull in a 3 pole contactor to energize the elements in the oil heater. When the t-sat is satisfied the contactor opens de-energizing the elements. Simple.
Here is the electronics part: The Thermostat has connected across its terminals,(in parallel) a capacitor. This is also shown to be the case in the control wiring schematic. The contactor has been chattering more frequently since it was installed 9 months ago. I temporarily removed the stat and capacitor from the circuit and wired in a single pole switch. The chattering stops. and life is good again. If it was a stat alone, I would feel confident in replacing the stat with a new one. My question is, what is that capacitor doing, how does it affect that contactor. Also how would I test a capacitor with a meter, digital or analog, to see if it is bad or good?
As I said my electronics back ground is lacking, so I would entertain any thoughts or even more so your professional opinions. Thanks for your help in advance.
