Car Charger not pulling as much when dryer is running.
td1236
California
Any thoughts on why a dryer running would cause a car chargers output to drop significantly? I believe the drop is 15-20 amps.
15-20 amps drop on input current or on output current?
What is supply voltage loaded vs unloaded? Or with/without dryer running?
You don't have one if these fancy things installed, do you?
