gar said:
080430-1020 EST
rexowner:
The reason I tossed out longer lengths than the specification is because this helps identify marginal capability.
Operation does not just stop at 100 meters but gradually degrades. In poor quality components maybe before 100 meters. Any of these problems can be treated with signal detectability theory.
Just because you connect two devices together and transfer data does not mean that you have a good system. If I take an RF link and consider the thruput with and without a microwave on that is 100 ft away and thruput drops to 50% with the microwave on, then is that RF link a good system compared to a direct wired connection? I do not think so unless RF is the only possible communication path.
The vast majority of problems with Cat-5(e) or Cat-6 are
termination, not cable quality. I used to support gigabit
ethernet products for a large manufacturer, and basically
all the physical layer problems were either poor
terminations or the electronics hooked up to the device.
Very rarely, there was a cable out of spec (e.g. didn't
meet Cat-5 specs.) I think Microsoft was mentioned
earlier on this thread as installing Cat-5e -- they
were one of the customers our company sold networking
gear to that was not baffled by the BS of the cable
manufactures -- they had smart IT people who understood
the issues and acted accordingly.
IMO, the whole Category-6 thing is a bit like if Cerro,
Southwire, etc. convinced a whole lot of electricians
to wire their tract home lite circuits with 10/2 and 10/3,
only worse. (I know a lot of devices only will take 12 or
14.) At least in the case of 10AWG, there are some
real corner cases, like lites a really long distance away
where voltage drop is an issue. There really aren't
any real world corner cases in the case of Cat-x,
Cat-5e will work just fine, but the the cable manufacturers
have just convinced people to install a more expensive
cable that they don't need by baffling them with BS.
