JFletcher
- Williamsburg, VA
Ahhh! Now there's a breath of fresh air!
-Hal
You forget I was a regular at the Sundance forum for some years (as you were)... and I figured I would correct 'em before you got ahold of them.
-Hal
is possible to have a wiring error and not use designated conductors of a pair, but you need to make same mistake on both ends of the cable for it to pass testing, then you still have proper continuity from one end to the other, just that not all "pairs" will be individually twisted like intended and it can reduce performance levels.That's what we thought too, until the cameras didn't work. When we tried one of the cable supplied with the cameras it worked. When we changed the pinning to reflect what the manufacturer specified because of the individual pair twists it worked.
You may have data speed issues, but if you accidentally swapped say the orange and blue, but kept the corresponding white that goes with each in the designated position, a continuity only test would still pass if you swapped them on both ends.If you punched down the pairs on pins 12, 34, 56, and 78, you'd wind up with 2 split pairs instead of 1 - green should be on 3 and 6, blue on 5 and 4. Even if identical at both ends, you'd be using one wire of the green pair and one of the blue as pins 1236 are used for signal transmission - that could get very ugly. Such a punchdown would never pass even a cheapie tester tho.
Lets not get carried away now. The USOC designations are still used although many designations like RJ-45 have no use today.
RJ-11 is your standard 1 pair phone jack or plug- 6p4c or 6p6c with T&R wired to the center pins 3&4.
RJ-14 is a 2 pair 6p4c or 6p6c jack or plug with the first pair on 3&4 as above and the second pair on 2&5. It could be used for two lines or commonly for office phones that use two pairs.
Extra credit: Does anybody know what a RJ31x jack is?
-Hal
Probably true 99% of the time but if your customer actually has or intends to on day upgrade to equipment that is capable of taking advantage of data transfer rates above 1 gigabit then CAT6 jacks and patch panels on CAT5E, regardless of how well installed, will not be sufficient. I would just make sure the trick is not pulled without that understanding.Neat little trick should you ever get a customer that wants an upgrade but doesnt want to recable the entire building.
I'd be willing to bet I could take a piece of cat 6 cable and wire it following 568B standard tho screwing up the colors and as long as both ends are identical, it would certify. Identical meaning brown on 1 and 2, blue on 3 and 6, orange on 4 and 5, and green on 7 and 8 (instead of the correct orange, green, blue, brown, respectively). The pair twist rates are important only in that they differ from one another.
One can take good cat5e cable that was installed to EIA/TIA spec (supported every 5', not kinked, not overpulled, under 100M in length) and put it down on cat6 keystones and patch panels and get it to certify cat6. Neat little trick should you ever get a customer that wants an upgrade but doesnt want to recable the entire building. Now 6a, dunno if it would pass that (Ive only ever done the aforementioned trick 'on the bench', mind you).
couple thoughts....
i read that the turn differences of the pairs were
a ratio to each other, not as absolutes on their own,
so that a manufacturer, as long as those ratios were
observed, could produce compliant cable.
i've got two cable certifiers that, while neither of them
is a $ five digit device, every cable i've ever tested with
them, at cat 5 or greater, assuming it's wired correctly,
has never failed a cat 5 cable or terminations at 1ghz cat 6.
That is the absolute truth, I've been preaching that for a long time. I've been putting plugs on cables for probably 20 years so you would think I would have it down by now. But I still have to cut some off and re-do them not to mention trying to figure out which end is at fault.
-Hal
It's especially difficult when you're color blind
Sesq, welcome to the forum. Here, we prefer to eschew obfuscation.Interesting to resurrect a seven-month-old thread, but refreshing to see someone else who understands twisted-pair theory, too. I have run and terminated plenty of UTP cable, and installed camera systems, too.
One more thing about twist rate: the greater the twists-per-inch, the higher the frequency (i.e., the shorter the wavelength) of interference that the receiver's differential amp can ignore (due to common-mode noise rejection) because the twists assure that both conductors pick up the interfering signal equally.
Yes, I'm primarily an electrician, but I've been interested in electronics and electrical theory since I was a kid. I built crystal radios when I was 6 (I'm 62 now), installed 8-track stereos when I was a teenager, modified audio equipment, and I am into A/V and home theater now. I remember token-ring networks using coax, too.
I read Popular Electronics magazine, and built stereo equipment from kits such as Dynaco and SWTPC, and read about, but never built, computers using the 6800 processor. i know more about hardware than software when it comes to computers. I prefer soldering irons and hand and power tools to keyboards.
Have a raspberry Pi trying to make security/pir/email/photo upload camera but don't know Python.)
Rewired an elementary school years ago with cat 5, I'm talking to the Verizon guy punching down the pot head, when a teacher stops and said how nice it will be to have high speed internet so they can access the university library miles away. She walked off and we both burst out laughing.
What was the name of the shunted term blocks, supposed to have their tool to term with?
Krone perhaps? Love them for demarcs.
-Hal
