Sounds like wet sumping and it isnt limited to Cats.
If I may on Saturn Europa's problem: gensets for WW plants are beasts, and they are usually designed for one thing: running the complete plant off grid. Yes, I know about paralleling them with POCO power to peak shave; at least the design goals. In practice, such a light loading causes the gensets to run far below what they are designed to do, they dont heat up to proper operating temps, and you have more problems than if you run them full song (at capacity). Those problems are high oil consumption, higher emissions, high fuel consumption relative to power, and increased maintenance. It is not cost efficient to run on internal power for any amount of time, for any reason. You do it because you have to maintain treatment.
I was at Nansemond plant when they got their twin Cat gensets, a massive improvement over the gas turbine that was there. Problem was the plant had vastly different power needs based on one thing: being able to gravity flow to the outfall. Normally, you can, and you dont need the (up to) 3 700HP final effluent pumps. But the gensets are sized to run the entire plant off grid, and pump that water against gravity, say like when a hurricane causes gravity outfall to become impossible due to storm surge. 1 Generator cannot run the entire plant, and 2 is massive overkill for all but the rarest condition (power loss during a monster hurricane).
Operationally, is it easier to reduce electrical loads by shifting anything that would be a batch operation to off-peak hours, than run a generator trying to reduce power costs.
They also had an 800HP gas driven aeration blower designed to run on digester gas. It's so massively oversized to gas production that it sits there, a very expensive toy, something some engineer thought a great idea (and it is), but grossly hosed up on the calculations.
Chris, probably 12-16cyl Cats in the 1MW range, tho I dont know SE's plant size
