We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
Acardin, you mustn't leave CAT.5e or any shielded cable not grounded or it will become an antenna for noises.
See ANSI/TIA/EIA-568-A-5
If you don?t need to ground the cable use UTP, It's much safer.
