JFletcher
- Williamsburg, VA
Many years ago, I was studying making a two way switch connection with a lamp and some wires after simply switching off the main switch (service disconnector) to our home. With no knowledge of my doing this, my brother switched the main switch on, while he was going out. I received a shock as I was giving connection but fortunately escaped without any injury.
Hence why I've ordered a LO kit. Faster than pulling a deadfront and removing the breaker or unlanding the ungrounded conductor.
Today I got bit doing a garage light. Long story short, breaker was off, wiring checked dead with functioning contact tester. Neutral wires (2) broke upon removing wire nut. Went to strip them and whacked I got. Checked again with contact tester, one neutral is now hot. :? Wire-nutted them back together and test again with contact tester; nothing shows hot. Didnt have time to investigate everything (will in the AM) but I suspect crossed-up neutrals from another circuit that had a load on it.
Quick side question: is it against code to have a j-box blocked by a light fixture fed from said box? iow, you'd have to remove the fixture to access the box. I think it would be tho I cant find it in the book. Not talking about like sconce or bathroom lights that are secured to the box, but like a 4 or 8' fixture secured to the building.
