Hello, could someone tell me what kind of wire this is I’ve seen it in a few houses and I cant seem to find what kind of wire it is. looks like NM but it has a cover ground? On the insulation it says NM-B-2 but I cant find it online?
Same here, and I've seen it hour-glass shaped to fit between the wires, in place of filler paper.I've seen 60's or 70's NM cable with green ground wire. It had the small size ground.
I thought Copperweld was steel core copper wire used for antennas?It looks like Copperweld NMB to me but I don't see where they offer it without a white wire.
NM-B
Type NM-B CCA Building Wire. Copperweld NM-B Building Wire is a welcome value to every stakeholder in the residential building wire space. Drawn from a copper-clad aluminum rod, with the copper metallurgically bonded to an AA 8000 series aluminum core, where oxygen-free copper forms a minimum of...www.copperweld.com
It is, as well as the center wire in RG-6.I thought Copperweld was steel core copper wire used for antennas?
Black anaconda brand nm had thatSame here, and I've seen it hour-glass shaped to fit between the wires, in place of filler paper.
With the CCA they're pushing the ampacity to color size so 12awg is white and 10 is yellow ect.Orange usually denotes #10.
This is the reason why I was under the impression that it was CCA, I keep on seeing the wire i newer houses I just haven’t been able to have with legible markings.With the CCA they're pushing the ampacity to color size so 12awg is white and 10 is yellow ect.
Well those guys who made up that panel were cutting the 1/4 in of sheath a bit tight as it isThis is the reason why I was under the impression that it was CCA, I keep on seeing the wire i newer houses I just haven’t been able to have with legible markings.
