JohnGS2000
We're having an issue with one of our local inspectors and the requirement for type of cable in buried conduit. We're installing RG59/U (UL) CL2P Siamese with 18/2 supplied for a CCTV Security application and in two areas this cable is run through approved underground PVC conduit. The inspector is stating that this cable must be direct-burial cable vice what we are using.
The question is - If the RG-59/U CL2P is in approved underground conduit, then why must the cable be rated/approved for direct burial and where in the code is this referenced?
I've done this for years now in the Security/CCTV field and this is the first issue that we've come up against. Thanks. JohnGShaulis@MSN.com
[ June 22, 2005, 03:59 PM: Message edited by: JohnGS2000 ]
