Hello all, been about 100 years since I posted a question here.
We have completed a lighting installation in a hard lid ceiling the same way we always have. We utilize the HVAC diffuses as access points to our J boxes and reach out to the many track lights at finish. The diffusers are 24"X24" "lift out" type with no screws. They also provide access to the "air balance" damper valves which are directly above the diffusers.
The 2011 code, 314.72D is very clear in that access simply must not require removal of any "Fixed Part" or "Structure" of which the diffusers in question are certainly not "Fixed" or buried in "Structure".
The inspector and his boss(verbally) claim that J-boxes may not be placed in or cause the removal of "other trades work".
The correction reads; "Can not use air ducting diffusers for access to electrical boxes above a hard lid."
In speaking to him, he stated his reasoning is that the ductwork may separate when access is attempted.
My response was that the air balance damper valves are up there. He said that the dampers would only be accessed once. I replied that access to our J boxes would be exactly zero after track installation and before the diffusers are installed.
Thoughts and comments would be greatly appreciated.
Thanks again!
Power Link
Thanks again!
Power Link
