chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
Can this blank be used in an outdoor soffit?
314.15 Damp or Wet Locations.
In damp or wet locations, boxes, conduit bodies, and fittings shall be placed or equipped so as to prevent moisture from entering or accumulating within the box, conduit body, or fitting. Boxes, conduit bodies, and fittings installed in wet locations shall be listed for use in wet locations.
Good idea Chris. Looks nicer than a 3" round blank.
I like it but it does not say:
'Indoor use only'
or
'Suitable for damp locations'
If you really are concerned about it then use one of these that are wet location rated. Just make sure you fill the holes---
If it was designed for indoor use, it may not meet the exposure to the sun test, and just turn to powder in an outdoor installation.
well, it's not gasketed, so it's probably not gonna fly for a damp location,
Due to this being a soffit install?I would use it and I would approve it as an inspector.
