Mom pulled the chain out of the pull chain high,medium,low fan speed control on her ceiling fan.
I replaced it with a 4wire switch from the supply house.
black -L
grey-1
brn-2
grn-3
High speed and low speed work fine, but it appears that the middle speed rotates as fast as slow.
Anythings possible, maybe the switch be bad?
I don't need high or low.... anyway I can use that switch just to operate the brown (medium) or is it more than line in and 3 separate load outs? Is the switch doing combinations of the 1-2-3 (gray-brn-grn) together?
thank you
black -L
grey-1
brn-2
grn-3
thank you
