1793
- Louisville, Kentucky
- Inspector
I have been asked to look at a job that would require a ceiling fan being mounted in a decorative beam in a bedroom. This is a vaulted ceiling with no access from above. There are two rows of three each recess lights on either side of this beam controlled by two single pole switches.
HO has been told that the new ceiling fan outlet can be wired from the existing lighting circuit wiring by the use of a DHC Control Dimmer/System.
I would like to know more about this setup if anyone knows or would be so kind as to share.
