Ceiling fan outlet required or not?
We can only hope that inspectors will use some discretion when enforcing this one.
But, as Streamline posted, aren't most round nail on boxes listed/marked for fixture support anyway? Was this a roundabout attempt to get a fan boxer requirement into the NEC?
I hope it extends beyond the inspector's discretion ....right to the State level as NJ did with previous AFCI requirements.
It's a truly ridiculous requirement that has little bearing on " practical safeguarding of persons and property from hazards arising from the use of electricity." and more to do with design issues.
Is a 4S and round mud ring rated for fixture support?
stickboy1375 said:
IMO this code is uncalled for... so in an attic I need a box being able to support 50lb's? thats some keyless fixture...
At every outlet used exclusively for lighting, the box shall be designed or installed so that a luminaire may be attached.
I am curious. Are there very many boxes where a luminaire may not be attached. Now keep in mind that what it says is that it shall be designed or installed so that a luminaire may be attached.:)
iwire said:
Thats a good point.
Attic, crawls, basements, garages.:roll:
The article in question specifies "in a ceiling." I think we are ok in your examples. But the closets and tiny bathrooms in a later post would be included. NEC 2008 314.27A
Why? Garages all of a sudden do not have ceilings?
Jim W in Tampa said:
NEC has turned into a sales thing,its no longer about safety but about forcing us to buy what they want to sell.
I don't agree. Yes, some NEC rules are very questionable, and I don't like the direction that the NEC is heading at all.
But the vast majority of NEC rules are still within the stated purpose of practical safeguarding.
Not what they want to sell, but what companies want to sell, the 2008 edition IMO is the most manufactured influenced I've ever read.
iwire said:
I have never seen a basement, garage or crawl without a 'ceiling' even if that ceiling is floor joists and plywood.
Around here we call those floor joists and plywood. But you can call them a ceiling if you like. The question is, what the inspectors will call them? ;)
