Re: Ceiling Fan Speed Control:
Sam,
With the right cap you could even have resonance which would yield maximum current, but I suspect that in a real motor, the capacitive reactance is the dominant factor in the impedance of the circuit.
Natheless, the motor speed falls as the applied voltage falls.
Your arbitrary numbers don't prove anything. Why don't you do some actual IV measurements with phase angles? I have only a foggy notion of the effective motor impedance. I only know that the current draw is in the order of one Ampere.
Sam,
