xformer
- Dallas, Tx
- Master Electrician
I recently installed 4 - 13/ 60w cfl's in a ceiling fan along with a cfl rated slide dimmer switch. When the cfl's are dimmed to the lowest setting, they flicker or slightly strobe. anyone run into this problem? This installation was to fix a previous problem of not enough light in the room. The customer has a newly purchased ceiling fan. The fan has a wattage limiter in the light kit limiting it to 190 watts. the 4 - 40wattt lamps that came with the fan are not enough light for the living room. Any suggestions on how to fix either opportunity??
