stickboy1375 said:I dont know, all the houses I do are wood siding... and I cut in old work boxes...
The box will also work on wood siding, make sure you get the proper siding lap size, installing an old work box, for a weather proof cover may not be the best method, to avoid moisture problems, the weather proof covers were not designed for switch boxes.
I found quite a few switch boxes misused for outdoor applications, and they all leached some moisture, or water, which lead to rot problems with devices and boxs.
Another thing to look at is, what if you need to use an in-use cover.
