- Chapel Hill, NC
- Retired Electrical Contractor
I posted that picture and from that angle I would not bet that the chandelier was in the tub space.
I hope you are just Kidding with me. Use the two pictures together. Use clues from each.
well, after re-reading the blogspot link - which does in fact state that the chandelier is over the tub (or at best, still within the zone, but not directly over the tub) - one click at the bottom of the blog lead me to this fascinating page of ritzy bathrooms, most of which have a dangly down luminaire above or far too near the zone. only one looks like it may actually be candles. Enjoy!
http://belgianpearls.blogspot.com/2010/10/choose-your-bathroom.html
Code not withstanding, I get a kick out of how worked up everyone is getting over this. You think nothing of installing a vanity light within a couple feet of a bathroom sink, but installing a chandelier 6 feet over a tub and suddenly people will be dying in droves. :lol:
The likelihood of someone touching the sink faucet while changing/touching the vanity fixture is relatively high compared to the likelihood of someone deciding to change the bulb in the chandelier while taking a bath. The likelihood of a child sitting with their feet in a full sink of water and reaching up and touching the vanity fixture is far more likely than an adult standing in the tub and stretching to touch the chandelier over their head.
Code not withstanding, why does one situation cause everyone so much angst while the other is a daily non-issue? For that matter, why does a 120 volt outlet in a damp location (garage or laundry) have to be GFI protected, but not a 240 volt outlet. Install a 240 volt garage door opener, and poof, it doesn't require GFCI protection.
Doesn't anyone ever question code?
If my posting sounded condescending, that's because you chose to read it that way. It was intended to pose critical thinking about code.Rick, that is pretty condescending.
This is an NEC code forum, we are talking about what the code requires, not what each one of us personally thinks about it.
Yes this is a code forum, but this discussion is about what everyone thinks of it, which is why there is such close analysis of some internet photos.
Code isn't perfect and can't take into account every situation. Without applying critical thinking to why code says what it says, it is just as likely to create a hazardous situation as it is to over regulate a non-hazardous situation.
Would the light be permitted in the normally prohibited zone, it it was fitted with 12 or 24 volt lamps, from a suitable transformer ?
I have just installed one here in the UK.
6 light chandelier fitted with 12 volt 21 watt vehicle lamps, 12 volt 150 watt transformer located in loft space above bathroom ceiling.
The lamps are cheaper, brighter, and longer lasting than line voltage ones.
